Hi Shaun, here I "copied & paste" a reaction from me on an article from Lothar about "Starting issues - ignition related" (6 may 2012).
I assume your Odyssey is an AGM battery so read further, maybe the effects are the same on your DMC2.
Before last winter I put an 30Ah AGM battery in my SFC 1000. The total voltage of Absorption Glass Mat batteries can go up to 12,95 ?till 13,1 volts. This is almost a 0,5 volt more that a traditional "wet" lead acid battery.
When running warm the engine and after many times cutting out the ignition (no spark) I tell the story to Gijs van Dijk and he knows that especially the DMC1 units (blue box) stops working above 13,5 volts.
My regulator is OK, but maybe voltage spikes in access of more than the 13,5 volt did stop working the ignition.
A few days later I got a kind of voltage regulator from Gijs wich he got from Uwe Witt and put that between the 12 volt wire and the DMC and gone were my problems! I did a little measurements and saw that the regulator drops the voltage to the powerline of the DMC to 9,95 Volt.
grtz, drive safe and wishes better weather than the last weeks, Ren?
