D
Davo
Guest
Piranha Brother 2 said:I thought you were OC?!
He's not OCD, he's worse, CDO - gotta have the letters in the correct order
I had to run the wires externally when I relocated the upper rear suspension mounts forward because of the increased wheel travel, could run them back there now with the longer shocks.Vince said:Had that one myself years ago,a lot of bikes have a metal conduit below the rear guard to run wiring through.Thats a big rear tyre on that bike.Tyres grow at high speed as well.
True, Vince, but they grow in diameter, which means they probably become a tad narrower as the centre grows. but, yes, I've relocated the wiring over the guard.Vince said:Tyres grow at high speed as well.
Piranha Brother 2 said:At 50% mine was definitely good at 4500, the only area I wasn't really happy with was at revs above maybe 6000. I still have a quest to build a SF/C type crank with all the counterbalancing built into the middle webs, even if it means loading them with mallory on the heavy side, then neutralise the outer webs. Try to get the counterbalancing as close to centre as poss, as per the pommie twins. The guy in Canada who does loads of then for race bikes has some great shots on his website of where he adds the weight.
There you go Red. I'll see how it works with my crank made from triple webs 3 and 5 for the inners, loaded with Mallory, and pared down SF webs for the outers. If it works, it will be the way to go in the future with the twisters. Of course, we could always find a way to incorporate balancer shafts as well!!sfcpiet said:I suspect you have a very valid point there Quentin. Reckon the uneven firing could exaggerate the rocking couple, the sheer length of the Lav crank making things even worse. Could well be the way to go, going to have a long think over that!
Tippie said:Use a toothed belt to drive the generator and unbalance it (never mind the bearings) :-X
sfcpiet said:fit one of those tiny Kubota thingys they don't mind which way they go round.
