Dellortoman
- Tasmania, Australia
G'day Tim. Welcome to the forum.
Pretty good summary.
Yes, I can confirm that. Left the ignition on overnight. Killed the lithium battery stone dead. It was only a few months old. A bit pissed off with myself.
I've been told by a lithium battery expert: NEVER put a lithium battery on a trickle charger. They don't trickle charge. If you want to top up a Lithium, put it on a normal smart charger for a little while, then take it off again. Don't leave it on charge unattended.
Tim Main said:a) Lithium-ion Batteries (LiFePO4 or LFP) - Good for starting, but v-bad if left to dis-charge fully, avoid if left with alarms etc that discharge over time
a Lithium-ion battery built into the casing of a classic 1960's BMW had exploded, due to an incorrect trickle charging type / system.
