whatever way you choose to remove the engine, try doing this, as soon as you have unbolted and removed the front triangular engine plates, insert a 10mm steel rod through the engine bolt hole about 150mm longer each end than the motor, this gives you a "handhold", then when you have removed the bolts from the slotted under case mounts and the four gearbox end mounts, move the motor forwards and upwards at the front end and insert another rod through the upper gearbox mounts.
I have found that those two rods are worth a small fortune in terms of easing the whole process, cam cover removed, pri cover removed, inner and outer gearbox cover removed, chain tensioner and plate removed, sump plug out (they are all gonna come off anyway so make it lighter and smaller), I lift the motor out with a helper, nothing more, done and dusted in minutes,
