Jota hot starting
Someone else, Paul. My SF was always spot on for carburation. I used to tune them (and every other brand of moto) for a living.
Sometimes a little 'enrichment' just made it easier to fire it up when hot. It was usually if the motor had been stopped for several minutes but was still 'hot' that it liked a little extra juice.
I just give squirt from the pumps and go.
  • Like
Reactions: IAG
Does that indical the mix screws are a touch too lean, I always add an 1/8 of a turn after finding smoothes screw setting and that usually gets a more stable idle. I do remember when I first got the bike it liked 3 pumps of the throttle activating the pumps to start, not so much in later years. You eventually learn what the bike likes and doenst like.
My bikes are strange, sometimes they need the choke when hot and other times they don‘t need…. but anyway I get them started….
No Vince. But a slightly richer than optimum idle benefits lift off idle and helps revs drop quickly back to idle. Mixture should be set correctly for the actual idle speed, not the cranking speed - which is why a little extra juice when cranking probably helps.
Most triples and the majority of twins require a whiff of choke/enrichener for warm starting. No big deal. Having a triple fire up immediately without the choke is a rare occurance.
