Sir Sidney Ruffdiamond
- Cotwolds
Love the look of the RC8 - the new one also looks the dog bollox - the show stand at Brum was full of bikes
At least you could say that KTM`s are never boring .........A friend bought a new 990, it ran nice for a few months and then the oil pump seized and the motor exploded.
Yup. I was 6’ from one when it let go HUGE all over the highway.A friend bought a new 990, it ran nice for a few months and then the oil pump seized and the motor exploded.
Ya,,,,hard no from me!
Painful to watch ......... seems a bit of a lottery to me as to whether you end up with a good one or not ........ £700 for an update which will cure all the problems though , so that`s alright then .....
That " Ready to Race " popping up every time ..... ( and just to rub it in , also printed on the handlebars ) .......................
Another thing I heard about the KR-1 was that some barrels that were fitted to the same bikes were machined at different heights , causing gasket sealing problems ..........Here’s an odd one- Kawasaki KR-1 250 two stroke , piston ring locating pins used to work there way into the piston causing the ring to revolve and cause catastrophic piston/ bore failure. This was remedied with a modified piston BUT warranty claims made were issued original non modified pistons until remaining UK stock was exhausted. I suppose by the time the engine had seized for the second time it was out of the warranty period![]()
BMW’s used to share ABS fuse with the cooling fan- if you get a stone in the fan blades the ABS will fail, great ideaAnother thing I heard about the KR-1 was that some barrels that were fitted to the same bikes were machined at different heights , causing gasket sealing problems ..........
Never quite sure about Kawasaki build quality ..... There was an article about a ZX-9R C2 or C3 which had covered 80 or 90,000 miles ........ Only thing was it was on it`s fourth engine .... ! .........
Regarding Triumphs ......... I`ve mentioned this before , but I bought a 1200 Bonneville Bobber from a London dealer ...... only 350 miles on the clock ..... an ex demo bike .
At around 2500 miles I was out on it , about half way between Cirencester and Cheltenham , when suddenly all the warning lights came on .
I stopped , and switched the ignition off , thinking that would clear it .............
Big mistake .......... When switching back on again , all the electrics were there ( including the warning lights ) , but the starter circuit was dead ....... nothing at all on the starter button .
Called out the AA ...... ( " nice looking bike , mate " ) ........ and we took it up to a Triumph dealer in Cheltenham . They kept it , whilst the AA transported me back home .
Caught the train up to Cheltenham the following day ..... Dealer said they had checked it over , and it was now starting and behaving properly ....... Nothing wrong as far as they could tell ..... see how it goes on .......
Ten days later it happened again ..... kept going this time , got back to my garage ....... switched off , then back on again , and no starter like before , and all the warning lights illuminated ......
This time it went down to Fowlers in Bristol ........ They kept it for a couple of weeks , then informed me it was fixed , and ready to be picked up ....
Fowlers had got in touch with Triumph , who told them they reckoned it was a fault with the ABS pump / modulator ........ Triumph sent a replacement down to Fowlers , who fitted it .... and that was that .
The Triumph warranty was still valid , so all the work and transporting of the bike was covered ........
I was`nt quite sure about Fowlers at first ....... They are now a big supermarket type dealer , supporting about half a dozen brands at once , but the service and repair work was excellent ...... ( as well it should have been , of course ) ........ The electrical components on the Bobber are scattered haphazardly around the bike ....... the ABS modulator is situated at the lower rear of the engine ..... ( the reg / rect is actually under the engine ) ....... so they had to dismantle half the bike to fit the new modulator ........ You would`nt know the bike had been apart except for some fresh electrical grease on the connectors , and whilst they had the bike they noticed the battery was losing charge , so they fitted a new one of those as well .
All covered by the warranty of course .... but after all that I lost faith a bit in the bike ......... If something similar happened in the future , with no warranty , there would be a fair old labour charge ....... ( the modulators are actually fairly inexpensive , to my surprise ) ........ It would be possible to do the work yourself I suppose , but It`s not something I would relish doing ........
A shame really , as it was a nice bike to ride ........ not a sports bike obviously .... it starts to run out of breath after 90 mph , and would top out at around 115 mph , but very responsive up to 90 or so ....... would leave the Mirage in it`s dust up to then , but where the Bonneville would start to fade around the ton , that`s where the MIrage is just starting to wake up , and from 100 mph onward the Mirage would leave the Bonneville for dead , of course .
As I mentioned , that`s not a criticism of the Bonneville ..... it`s not meant to be a sports bike after all , and you would ride it bearing in mind that lack of top end performance ......
But anyway it`s gone now ........ it went in a direct swap for an extremely simple ( and electronics free ) 7900 mile 1998 R1 .............
