You need to cut a scroll into the bush ..... and ream the bush to sizenext thing is bronze bush for clutch basket. I noticed that there is no oil scroll in new bush. is this ok or i need to make a scroll ?
Usually, not always, there is an "0" stamped on the oil pump drive gear located on the crank. This should be at the slot on the crank.
Do you really mean 20mm, Phil?! Or 2mm? And what is the purpose? To increase uptake of oil? Have never heard of this upgrade mod.phil37 said:To increase the oil circulation round this part of motor and get rid off a bit of a "dead" spot - bore a hole (about 20mm ish) as in photo - sorry about photo quality! - regards - Phil
Piranha Brother 2 said:Do you really mean 20mm, Phil?! Or 2mm? And what is the purpose? To increase uptake of oil? Have never heard of this upgrade mod.
chrisk said:... it's in the same spot as the triples, but theirs are a little higher than Phils marked position.
