michipons
- Palma de Mallorca
Hi all,
I am starting to rebuilt the Borrani R18 wheels for the Laverda 3C. (Never did that before)
I would like to change spokes and nipples, do they need to be from a Laverda supplier or standard aftermarket (stainless) will work? I found several sellers in Europe, that apparently could fit:
https://www.e-spokes.eu/p20,stainless-spokes-sm-3-9mm.html
I measured the spokes and should be around 170mm? but I can order them by 1 mm steps, so maybe i can adjust more, the thing is that with the curve of the spoke I can't exactly measure it... and should be 3'9 as this web sells... or should be 4?
I haven't disassembled the rear wheel yet, but if any of you would know the length for the rear wheel... then I could already place the order for both wheels.
I guess is almost imperative to assembly the new spokes on the rim with a centerer? and approximate nipple torch value.. 3nm?
Regards and thank you for the help as always,
Miguel.
P.s. It came through my head to clean polish and re-zinc-plate both spokes and nipples..... but I think it is may be going a bit too far..?? (I ordered a kit by classic plating for other stuff... so why not?)
Miguel.
