Dellortoman
- Tasmania, Australia
This is how slowly my brain works ...
I need to pressurise the cylinders in my old Datsun 260Z to install new valve springs without removing the head. I figured I'd cobble together an adaptor from a gutted spark plug and a Nitto air coupling so I can connect an air hose to the spark plug holes. Then I figured I may as well incorporate a valve and pressure gauge. By measuring pressure drop in cylinders over a fixed time interval, it would also work as a kind of comparative leak down tester. But then I had a look at the price of leak down testers on ebay, and I couldn't make one as cheaply as I can buy a proper regulated dual gauge unit that will work a whole lot better.
http://www.ebay.com.au/itm/New-Cylinder-leak-down-tester-compression-leakage-detector-kit-set-petrol-engine-/162236210038?hash=item25c6081b76:g:eRcAAOSwYIxX~dA5
Blimey, if I'd realised the things were so cheap ($31 including postage) I'd have bought one years ago! :
