sideshow
Piranha Brother 2 said:Aren't the Marchals pretty close to the fairing? I suppose if yours is too difficult you can always revert to the quartz globe.
I've made the adapter for one side. Hole saw, metal sheers, die grinder, angle grinder, files ... took me probably an hour and a half to make ONE!! I probably should have checked if the headlight in that small size was available for a std H4. Oh well, only have to make them once!
I have the lamps attached to a bracket and then the bracket to the fairing, it gives me a bit of space to play with, I can make the bracket sit out a few more mm, or I can set the marchals off the bracket a few more mm, 6mm give or take wont make too much difference .I definitely dont want to run standard bulbs and kill the lithium battery.
