I've found that the strainer is only of any use immediately after an engine rebuild, mostly gasket goo remnants that have been washed off the insides of the cases are collected. A magnetic sump plug will at least collect the ferrous bits floating around, all else contiues on its merry journey.
The later strainer as used on the 120 engines is far more efficient, but also more prone to blockage as it has a very much finer mesh which will actually catch larger bits of metallic grit.
Mine haven't been out for donkeys years, they're inspected and cleaned at the first oil change after any major engine work... if I remember to.
