First ride !!!!
Took the Mirage for mandatory safety inspection yesterday.
It just breezed through with more time for paperwork than for actually inspecting the bike as it was obviously OK.
I then could try it...
I only did something like 10 minutes and then changed the oil again as the bike sat for 10 years with no valve cover, who knows what fell in there...
It goes well, really well with tons of torque from 1000 rpm.
The transmission shifts well enough but requires a stronger actuation than what I am used to.
The brakes are ok no more but I am using a modern Nissin master cylinder on the front as the re sleeved one I bought turned out to have a machining flaw and does not work so maybe it will be better with the proper master.
My approximate jetting while giving excellent response was in fact on the rich side as a plug removal at the end of the day revealed.
A little fab work to hook my innovate wide band meter to the exhaust will get me through this in no time.
My friend Gilles who owned this bike before passing away last December would be very happy to see it now.
So thanks a lot to all, while I did not ask that many questions I certainly did use the "search" button a lot !!!
The amount of info available here for Laverda owners is just incredible !!!!
In no particular order:
