cwis said:Ah ha! That explains the scratches on the inside of my gear change cover when I removed it to put the original clutch actuation lever back on. One washer was on the inside of the spring, one was outside of the case behind the lever!
I know what I'll be doing this evening....
Cheers for the info as always Piet!
Bloody hell the clutch is heavy now. And that's after I spashed on the Venhill featherlight clutch cable too! I best man up a bit, do my hand exercises and stop moaning....
Chris,
You'll need one washer on the outside to keep the o-ring in place!
