R
Reggie3cl
Guest
Well if you are running standard cast wheels and iron discs, nowt. They weigh a bleeding ton and the calipers are relatively light, but calipers behind the discs look tidier IMHO.
There are plenty of reasons why two machines may have different cornering characteristics. Make an inventory of those reasons and eliminate them before attributing the difference to calipers behind fork legs.I can understand the advantage in steering dynamics by getting the front calipers to the lower rear of the forks and am considering doing this fork swap on my 1976 3CL. I recently had a chance to ride a 1982 model with this configuration and noticed better stability in cornering.
I would be interested in any feedback, good or bad, from anyone who has done this.
Considering this thread is 11 years old, there may have been more who have done this since then.
Of course you brake into a corner. Days of grabby drum brakes and tyres made out of soap are long gone.Swapped my RGS calipers around a long time ago and there is a reduced tendency for the bike to stand up in a corner. Yeah, I know there's argument for and against braking into a corner but I'm now a firm believer in trail braking. If it's good enough for Simon Pavey...
And on Clem's point braking performance in wet weather is unaffected... both with standard CI discs /organic pads and stainless with sintered
It was the first change I made when I bought my RGS not because of the way I habitually rode, but to improve the odds in case of an emergency situation. Did it make a difference? Who knows? But I felt better about my confidence in the handling and it looked better IMHO.
?Swapped my RGS calipers around a long time ago and there is a reduced tendency for the bike to stand up in a corner. Yeah, I know there's argument for and against braking into a corner but I'm now a firm believer in trail braking. If it's good enough for Simon Pavey...
Good points Paul. I have replaced both front and rear alloy wheels with wire spoked wheels which, in my opinion, made a significant improvement in handling by reducing the un-sprung weight and associated unwanted inertia, as Clem pointed out. So, yes, that is a major difference from the 1982 and my 1976 model. As for cornering, like Rob, I prefer trail braking where possible. I think Cam is onto it--the advantage comes from getting the calipers closer to the steering axis.There are plenty of reasons why two machines may have different cornering characteristics. Make an inventory of those reasons and eliminate them before attributing the difference to calipers behind fork legs.
What kind of riding do you do? Are you in the habit of coming into corners hard on the brakes?
Did you weigh the cast wheels and the wire ones? What was the difference in weight?Good points Paul. I have replaced both front and rear alloy wheels with wire spoked wheels which, in my opinion, made a significant improvement in handling by reducing the un-sprung weight and associated unwanted inertia, as Clem pointed out. So, yes, that is a major difference from the 1982 and my 1976 model. As for cornering, like Rob, I prefer trail braking where possible. I think Cam is onto it--the advantage comes from getting the calipers closer to the steering axis.
As for appearance and maintenance, I'm not as concerned about that, it's more about the handling.
That shows how long ago I did or didn’t do it!?
RGS came with calipers fitted behind the sliders as stock.
If I'm not entirely mistaken, the mod was introduced by the factory with the Jota 120. A few pre-production factory pics show the calipers in front of the sliders, production bikes had them behind.
I weighed the rear. I eliminated 5kg by using KLR650 17" wheels. I guess it's now a KLaveRda.Did you weigh the cast wheels and the wire ones? What was the difference in weight?
Braking performance would have to be the same. It is steering that people are addressing, and peoples feeling of steering is part of that nebulous term "handling". Are there any bikes made today with callipers in front?Was discussing this issue the other day with Norwegian Laverda racer, Rune Vangen. He said having tried both ways round he couldn’t notice any difference in braking performance between the two. I can’t say I have either on the 500 twin, although I do tend to reverse them on my track bikes.
