Yogi
- Bellingen NSW Australia
redax5 said:is an early small gasket barrel, not really worth the purchase and postage cost from Europe
Thanks Red - the things you learn...
Yogi
Grant said:Aye, for a 1000.
CLEMTOG said:It can be argued that the early gasket shape is superior, because the pressure over most of it is constant, whereas with the large and (cheaper to make) set up the pressure varies widely over the face, just look at the dimensions from the 12 stud holes to the edges , comparing both and you will (maybe) get what I am on about (maybe not)
2018-03-25 12.24.05 by Grant Duguid, on Flickr
2018-03-26 11.26.00 by Grant Duguid, on Flickr
2018-03-26 11.27.56 by Grant Duguid, on Flickr
2018-05-03 12.41.12 by Grant Duguid, on Flickr
2018-05-03 13.30.45 by Grant Duguid, on FlickrGrant said:Quick update.
Frame and general black work all powder coated.
New swing arm and steering head bearings fitted.
Various parts ordered but still trying to find 1200 barrels, anyone?
Found an original shaved down primary cover, unique to early 1200s, prior to Marzocchi suspension update. Result! Had been considering having other type shaved down by CNC machining.
Bodywork away for painting, decided on the red option.
Still a very long way to go.
