My New Project
  • Thread starter Thread starter Grant
  • Start date Start date
Doubt it was a simple cornering clearance issue that did the damage. Yours has taken a solid hit from behind to pull it out of the case like that. You can see evidence of something hitting the back of the socket where the adjuster bolt goes. I reckon the adjuster bolt that came out of it was bent. Happened during a crash most likely.
Not that it matters how it happened. Repair is the same.
I see some small damage from the rear but much more force is from the side.
This is consistent with side load from the adjuster nut decking hard.
I have seen this several times.
The nut decks and the adjuster bolt levers the casing, which splits in this fashion.
Yep, all 1200s had laid down shocks.
The upright mounts were still there (they only disappeared around the series 2 revision) but the shorty grabrail uses that mount.
If you want to you can still mount the shocks upright, but why would you?
Why would I put a carpet on the workmate? The wood is soft enough.
Who knows. Was good enough then, why wouldn't they be up to it now?
I have tubeless radials (BT016S) on my current bike, but would happily ride this 1200 on TT100s.  :D
Mine lasted a couple of weeks until I got sick (scared of them), and they were brand new.  Got one of them new fangled Pirelli Phantoms on the back and a Dunlop KR124 on the front - of course you can use them on the road officer....
Those TT100 tyres can't be too bad. I followed my brother on a bit of twisty road when he had them on his 3C and they seem to hang on pretty well if his lean angles were anything to go by. He was chucking it around corners faster than I was game to and I had BT45s on my bike.
They're certainly a lot stickier now with today's modern rubber compounds than they were back in the 70s. I like the classic look of the tread pattern too.
