new member with a 750 - random musings, questions & updates. :)
My father gathered all the stuff he had for the 750, went to see him today to pick it up. Haven't really sorted it through, but some nice powder coated fork legs, what looks like the original airbox, an exchaust system pretty good condition, the GT fork shrouds, the orginal to the bike (short, rubber bushes) swing arm, lamp and instrument holders and a cylinder block with pistons, SF(?) front fender and lots of other stuff I'll need to sort out. Happiest with the exhausts and fork sliders (not pictured).
The contraption left foremost is one I cursed at often when I was a kid and we went on vacation, that dreaded luggage rack that cost me my leg room!
I still had the leaking fork seals to fix, and with the boot full of Laverda parts set about to do just that. As always with old stuff of course it wasn't quite as straighyforward as I imagined. In the pile of parts were at set of nice black powdercoated sliders, my father had already cleaned them and put new seals in for me. So, drain old oil, disassemble, fit new sliders, reassemble, new oil, re-adjust the brake, and done?
Well... turned out after I had done all that there was a krr-krr-krrr-krrr sound coming from the wheel hub. The brake also didn't really want to adjust the way I felt it should -pull deep, spongy feel. The noise came from the side of the speedo drive, so I assumed that was it. And it turned out that was it indeed, but that sound masked the sound of the wheel bearings, which were krr-krr-krrr-ing along with it!
Replaced wheel bearings, disassembled the speedo drive, cleaned it up, new grease, better, but still not great. It still works, though... The speedometer cable was full of sticky grease and although I have no reference with a "known good" cable, it does seem to turn a bit on the sticky side. I'll clean it and lube it with some oil to see if that helps but will probably get a new one anyway. I just hope the speedometer itself is not the issue.
Speaking of cables, th front brake adjuster wheel threads were shot, and turned out when I pulled the cable further out to have a better look it had some loose strands.
As, later on, I also wanted to re-adjust the shifter and replace what feels like a lame spring there, I ordered stuff last week (from Gijs van Dijk).
Also got 2 thicknesses of rings for the neutral switch, so when this front end stuff is done, at the next oil change I'll look into that, but it's more a nice to have.
Always something with these old workhorses! ;-)
Thanks! I had this post by (sfc)Piet bookmarked for that stage.
But obviously will fit a new cable first. The broken strands were in a really odd place, barely visible or I would have noticed earlier. Also glad the lever side adjustment mechanism is still available from Gijs. I've always felt the there was too much free play. Hopefully this will cure it, otherwise there's probably more work ahead...
Kind of a bummer though, now that the weather is nice I'm still messing around rather than hopping on and going on a tour. Annoying stand-in-the-way-things, unbalanced motorbikes without a wheel!
Little update. I cleaned the speedometer cable, and re-lubed it with some light oil. When I insert the inner cable slowly, turning as I go, at about 3/4 there's a friction spot where there's more resistance. I compared it to the (albeit shorter) newer revv counter cable and that runs a lot lighter.
Turns out Gijs does not have them in stock, so I've called a local company who can (hopefully) re-create one based on my old one.
Also re-fitted the wheel, fitted the new adjuster and cable, and adjusted the front brake. It feels a lot better now -although I don't have references how it can be ;)
Hoewever... I forgot to fit the rubber boot covering the adjuster so I can re-do most of it again. Soon I'm able to do this with my eyes closed :D Yes, the bike is a scruffy old thing ;) Looking at the adjuster setting there may be more work in the future.
A: those engines are noisy, it'll cover the noise from the cable.
B: adjustment is probably due to the cable being unsuitable.
A is definately true ;) Although it is the drive itself, not really the cable... which appears to be the cause of this.
B: I got the cable from Gijs van Dijk, I suppose he should now what does and does not fit... might also be wear on the linings, as the bike has done a fair few kilometers... At least the brake is a lot firmer than it was, so that's a succes (and no frayed cable!)
That would be a lot of wear somewhere.
Yes, true... I put it all back together, already does feel a lot better than it was. (although I still need to ride it to be sure).
I'll put the Garmin on for now, and cover the speedometer drive openings until I get a new cable. At least I can go out and about :)
