Finaly found a day without rain or 40c temps and managed a few laps around the block to test the new springs and its a lot firmer, to firm actually. The cable tie on the shock sharft stopped approx 10mm off bottoming which would be ok, except that block has a bunch of very big speed humps. Those speed humps should have resulted in some bottoming. Coincidenty I read a post by Terry Hays about using cable ties to test travel.
Quote
Tying Yourself In Knots…..
The use of zip ties as travel indicators has become common place these days, but beware….. they can be a double edged sword.
They can be a useful tool when used thoughtfully but do have the capacity to create confusion…. as well as damage.
They “Will” tell you how far your suspension has travelled but unfortunately not “How Often”.
So if you were travelling from Sydney to Melbourne on your road bike, you could be spending most of your time hovering within the middle of the suspension range and then you pull into a petrol station to re-fuel.
There could be a spoon drain or perhaps a speed hump that almost completely compresses the fork. You don’t give it any thought at the time….. Next thing you’re sitting in a café in Melbourne and looking at your bike (obviously a Tri Colour Monster)
and you notice that the zip tie is right at the bottom of the fork…. Shit!. My suspension is bottoming out!
Choking on your latte….you go hurriedly searching through your Ducati back pack, rumbling through your Ducati T shirts, Ducati sunglasses and sneakers to find your Ducati Iphone so you can call Frasers roadside assistance. Come quick!!! My shocks are bottoming out!!!
So in this case the full travel was used only once and under exceptional circumstances…..not the norm.
Some people also make the terrible mistake of putting a zip tie on a shock absorber shaft, once again to monitor suspension travel.
This is almost always done without the knowledge that the bump rubber is part of the suspension travel. Bump rubbers are generally about 15 - 20mm thick and extremely compressible. This can potentially represent up to 30 - 40mm of rear wheel travel.
So your zip tie could hit the bump rubber and you still have a lot of travel left. Or the zip tie will hit the rubber, the rubber compresses and expands again, pushing the zip tie back up to the top of the bump rubber, potentially disguising actual suspension movement.
If this happens repeatedly, the zip tie often tears the bump rubber, which ultimately leads to its destruction.
A similar thing can happen with the dust seals on the forks. If your normal fork travel sees the dust seals right at the bottom of the tube on full bottom out, then the addition of a zip tie quite often will destroy them. (Travel 1 in diagram)
Some fork tubes bottom out whilst still leaving a portion of chrome tube exposed. (Travel 2) There could be 15mm of chrome tube still showing with the fork fully compressed. In this case the zip tie will do no damage but if you aren’t aware of where the bottom out position actually is, you could have a false impression of where you are in the stroke.
I would prefer to see people use an o-ring on their forks rather than a zip tie. They are far less offensive to the fork and more pleasing to the eye…..just be very cautious when making your assessments.
https://www.facebook.com/groups/978921352552169/?__tn__=<
