So did a lot of mundane stuff this morning like testing a new earth for all the wires in the headlight, checking the horn potential bad earth and removing the starter relay connectors and cleaning rust off them. No change.
Anyway went back to Coils and I am positive that there is a problem with the double coil.
Why? Well...
1. Single coil DOES spark strongly.
2. Double coil sounds like it sparks but DOES NOT actually visibly spark
(Note I have tried this with the coils isolated from the bike and not.)
3. I then switch the wires (power and trigger) around completely so the Double coil has the wires from the single coil and the double coil has the wires from the single. Double DOES NOT spark and Single DOES.
(Note I've also tried leaving the supply wires to the coils as is also in this test, and I've eliminated the HT leads as the problem)
So there is literally only ONE thing it can be which is the double coil. Do you agree? If not please tell me why?
Not sure whether I am chasing the original fault here but this is definitely the point of failure.
EDIT: Anywhere on a Sunday in Oz I can buy a suitable replacement coil ? Improvise?
Why? Well...
