Phf32
While replacing the needle jet and needle,
(Phf32 sfc1000) The new AB265 don’t screw in as far as the old ones,
The old ones measured approx -11mm from the edge where the main jet holder meets the carb body, to the jet, new ones are only 6 or 7mm so sit lower in the carb
I assume all 3 should be approx the same,
But can’t see a reason why the difference,
Anyone seen this ?
Thanks in advance
Stuart
I've corrected my mistake... it's M7x0.75.
Apparently currently available jets are machined to different tolerances than the older types. When installing, a definite stop should be felt, not just a gradual tightening.
