Playing with a 76 Jota
Hey Marty. My 76 Jota had an almost identical misalignment between gerarbox cover and the top part of the crankcase, just like yours. I wasn't sure why it was like that until I had a closer look.
As others have suggested, a bit of investigation revealed that it had been clobbered by a busted drive chain at some stage prior to my ownership. One day when I had the cover off, I cleaned all the greasy chain muck off the inside and found that the case actually had a hole in it that had been patched with body filler and painted over. The plug of filler had detached itself from the alloy come loose. At that stage it was only held in place by mechanical entrapment.
I knocked the loose chunk of bog out and tried to straighten the remaining bent part of the crankcase, but as soon as I touched it, it broke off. Rather than strip the engine to get it welded up, I re-built the missing portion with fibre-reinforced epoxy. After a sanding it back to blend in with the shape of the crankcase and giving it a coat of aluminium coloured engine paint, it looked pretty good. Nobody can tell it's been patched by looking at it from the outside. At least it's not misaligned any more so it looks better than it did when I bought the bike.
Some might consider it a bodge. But since it's not heavily loaded and doesn't have to hold oil, I reckon the epoxy patch is as good as any repair method. It's certainly a whole lot easier and cheaper than stripping the engine down to the bare case to get it welded up. I'll leave it to the next owner to do a welded aluminium patch if they object to my epoxy job. I'll most likely be pushing up daisies by then.
I am not the calendar boy, I am the one in the avatar to the left with the orange shirt, Richard Slater is the other, sometimes known as the four eyed short arsed Brummie, now retired,and fully justified after all his years of keeping the best parts stock in UK, we dont realy have one any more, most things are available, but there is a need to (usually) go to more than one supplier to satisfy the never ending list.
