AndyW said:+1 (bigthumb) He retired recently didn't he? Did the business die or did he hand it over to someone?
Was that downchange intentional Thomas?Thomas aus LAU said:I've already learned the hard way.
The chain rupture happened at 180 km/h at 7,500 rpm when I shifted from fourth to fifth - not funny.
Brettoni told me he had several times the same experience. A maximum of 10,000 km is a must for the SFC.
My recommendation:
- normal 750 + correct oil change: change chain each 50,000 km
- sporty driven SFC or tuned 750 + correct oil change: change chain each 10,000 km
Chain:
switch to two high-quality reinforced single chains (same charge)! E.g. from OCT.
You have four connecting links each, but the one by the single chains are much stronger.
toothless :-X
Better:
Thomas aus LAU
Tippie said:Was that downchange intentional Thomas?
Thomas?picture Clem. Mine are Jwis, supplied by Andy before he retired. They are also very heavy duty, might be able to find a pic if you want. I also got a sinlgle row to use as cam chain on my SF race bike, if I decide to, and that one, same pitch, is not as heavy duty as the primary.CLEMTOG said:Tippie, your twin simplex chains, pictured above look much heavier than the three that I saw broken, do you know what make and type they are, the ones being supplied (in the past) by UK outlets look more like bicycle chain in comparison.
Nat Magee said:My SF3 came with 2 simplex and terribly noisy. One was stretched more than the other so I got a duplex from The Chain Man, Iwis I think. Apart from the exhausts a lot quieter now.
Paul Marx said:Twin chains are noisy and cannot be tensioned to reduce noise, probably due to uneven stretch.
In SA eh, would that be Twiggys latest purchase at a cool 200mill?Brett said:for shoe wear suggest a cobbler would be very helpful I have issues with the heals of my boots wearing out over time so once a year they go back to the factory in SA for a retread 8) 8)
