I've never quite got the point of indexing plugs so the open end of the side electrode faces in a particular direction. I've seen recommendations to face the plug gap towards the inlet valve, and others that say to face it to the exhaust valve. I dunno why facing towards one valve or another can make much difference because both valves are closed when the plug fires. So I did some further reading, only to find that some engine tuners don't refer to the valves at all. Some say the open side should face the squish area, others say it should face the piston crown. The only conclusion I can draw from all the different recommendations is that nobody really knows, and that the whole indexing plugs thing is nothing more than a myth.
The only indexing that makes sense is in a 2-valve head where the plug is off to one side of the combustion chamber. If it overlaps the edge of the squish area, there's a possibility that piston clearance could be an issue in a high compression engine. In that case, it may be necessary to to keep the side electrode away from the piston crown.
