S
silvo
Guest
Or just buy some brown vinegar.
Dellortoman said:Spent today making up some fairing brackets and mounting the SFC-style fairing on the track bike. It'll look better when it has the bubble screen on.
laverdakeith said:It would look better still if you drop the front of the fairing by four or five inches. To make them look fast and sleek the bottom of the fairing should be parallel to the road, that is why 1980 Jotas look gawky and stupid and 900ss's look sleek and fast, they both use essentially the same shape of fairing its all in the angle of the dangle
Keith
Davo said:Got it out for her first decent ride since rebuild, rego and Red's recommended alteration. Only 60km to see what would fall off. Apart from a leaking seal under the top cap of the front mastercylinder all went very nicely. Longer run next time.
Oh, and that green really stands out from the crowd. 8)
Keith
chrisk said:Cam, that fairing sits way forward too.
Vince said:Cam have a look at allowing the cam cover to come off with the fairing still mounted. Make life easier with maintenance jobs.
Yes - it was a bit of a mess and ordeal to finally get them out. Probably the single most frustrating mechanical experience I've had yet...MotoV said:That just doesn't look good....
aebbern said:Yes - it was a bit of a mess and ordeal to finally get them out. Probably the single most frustrating mechanical experience I've had yet...
chrisk said:Any other way than what you've done is frustrating. Good work.
I tried to use my blind bearing puller - it wouldn't bite strong enough on the metal and simply pulled through. The welded washer was my last ditch attempt.Davo said:Apart from using the correct puller, of course.![]()
