Dellortoman
- Tasmania, Australia
I don't think I'll qualify for anything Centrelink has to offer.
+1tom3c75 said:Lovely bike Maurice. That metallic green looks very good indeed.
Paul Marx said:Piet is going to roll over laughing.
:-X....
.... My theory is the following. The vibration of the exhaust system on my SF2 induces forces, notably rotational at the exhaust port. This tends to grind away the copper exhaust gasket, adding to the natural tendency for the nuts to release as the copper gasket is compressed. I seem to remember the mating surface of the tube with the gasket appearing polished when I looked last weekend. Will check again next weekend.
If my theory is correct, the solution would be to clamp the tubes before the silencer, the other end of the clamp being unobtrusively bolted to the lower engine mounts.
Any ideas? Any feedback from people running early GTs or drum SFCs?
tyelav13 said:Quick question, can you still get the original system?
Regards,
Tyrone.
redax5 said:you have got 2 x single coils on that bike haven't you Chris ?
is hard to see in that photo, just looks like both leads are terminating close to each other
mauricejota7604 said:Finished one of my drummers!
chrisk said:Red
No coils at all, but it will have two 6ohm jobbies as per your advise.
That terminating is actual a billet lead seperator, the lead and cap ends are out of the shot.
I set them up with the 3ohm Dyna coils I have, I hope the 6 and 3ohms are both the same physical size.
Your place called Hollywood by any chance Maurice? The dream factory.Finished one of my drummers!
