Gravelroad said:I'd guess you might have just started with the wrong cable from the beginning. Your GT is a 1973 build, same as my 3C. I'd take a bet for a vino rosso at Breganze, that both bikes should have been fitted with identical rear brake cables ex factory. Hard to imagine that a rather small manufacturer like Laverda could afford such atrocities like different cable lenghts on otherwise identical setups.
In case I'm right, your looking for a cable with 62cm length from tip to tip, cable sleeve with 36.5 cm length including the pressed on endcaps, and an adjuster with overall length of 5.5 cm.
Think you"ve cracked it Stefan, a quick measure this morning (slight curve on my cable) is showing 67cm,41.5cm and 5.5cm respectivley .
Many thanks for your time on this.
Shaun
