Hi Cam, I'll take it off your hands, email me.I just measured a couple of sprockets. The centre hole measured 122.85mm. So I'd guess 123mm nominal ID, allowing for me not holding the digital vernier straight across a diameter. 4 x 10mm bolt holes on 140 PCD
I have an unused spare 42T sprocket if it's any use. It's solid steel without any lightening holes so it's about as heavy as a Laverda rear sprocket can get, unless you make one out of uranium. Nothing to stop you milling out a bunch of holes though.
Hello Vince, yep you*re right - I fitted the supersprox stealth rear sprocket to my Ducati couple of years ago - supersprox don't do an off the shelf item for a 3CL, however, the have a customer service where they will produce to your dimensions. Feedback was super-quick; got their offer today and paid me money (euro 80) - they've promised a 3 to 7 week delivery - suppose it depends on when they have enough different sprockets to make a production run worthwhile. Will keep you posted.Well thats interesting, as these rear sprockets are hard to see with the chain guard plus the chain covering most of it I have had a couple of multiday rides spoiled with suddenly noticing either damaged or worn out alloy sprockets mid-ride. So I now run a steel rear sprocket, there pretty heavy so having most of the sprocket alloy but having the outer bit with steel teeth would be a great compromise wight and strength-wise if I have what you're saying right.
Thanks Gert, that's quite a good deal they have - already had a front sprocket up when I was in England last year, chain I ordered last week from LOUIS (they have reduced prices for DID chains at the moment) & I have just ordered my SUPERSPROX rear. Let's see how it works outHi Russ, if you are looking for a complete chain and sprocket kit for your 1000 3CL - here you can get for a nice price:
Ciao, Gert![]()
DID Kettensatz LAVERDA 750 SF 1974 - 77 19 / 40 / 106 DID530VX3 G&B X-Ring gold
DID Kettensatz LAVERDA 750 SF 750 1000 - 19 /40 / 106 DID530VM(G&B) X?Ring extra verstärkt goldwww.motorradtechnik-engelmann.de
Looks like it was anodized and then the holes & slots machined in, sort of confirming what you say Jim...Well ....... that looks good ....... I suppose the outer sprocket is a standard size and just the inner fitting is bike specific? That would be a very nice option indeed.
Jim
That looks like a considerable weight saving, Russ.
Do let us know how you get on with it
That's only going to multiply the unsprung weight ratio, Russ, further improving suspension performance.will do me weighing the other side of 140 kg though, the weight saving was not my real consideration![]()
As I live in Austria, sprocket was manufactured in Poland - you have to fill out the custom sprocket requirement on the supersprox main website https://www.supersprox.com/supersprox-custom/#CustomSprocketSection and they forward it to the nearest guy based on where you live. They have a range of 7 colours for the inner anodised part - turnaround time for mine was ca 7 days from receipt of order and payment confirmation.Nice.
Made in EU, but where?
NITRON rear shocks waiting in the wings for just that purposeThat's only going to multiply the unsprung weight ratio, Russ, further improving suspension performance.
yep you're absolutely rightWell ....... that looks good ....... I suppose the outer sprocket is a standard size and just the inner fitting is bike specific? That would be a very nice option indeed.
Jim
Sorry Chris. I only just noticed this reply from you.Hi Cam, I'll take it off your hands, email me.
Chris
