Exactly. Difficult to get the stock disc to fit with those wheels AND retaining the stock anchor on the swingarm.
Quentin, getting the caliper lined up with the stock disc while it is above the swingarm isn't possible with the stock type bracket, no space, unless you cut a chunk from the swingarm. Wasn't an easy task machining the brackets back then with our rather rudimentary facilities, I would have gladly passed it on... but Herr Witt insisted on the finished product looking "factory", which it indeed did. The conversion eventually even attained TÜV approval!
The rearward position of the lower shock mounts of the SFC/Spaceframe frees up a lot of space required to locate the caliper upstairs. Road swingarms are a lot more cramped. A lot easier to start from scratch with a more suitable/easier to work with caliper and anchor point.
