chrisk
- Brisbane, Australia
What a lovely looking motorised bicycle...... a credit to you.First test 20 mins and it ran well, what a novelty being able to have the headlamp on
Near future is a relative termI am waiting for Keith to send me my kit, so I too will be fitting one of these in what I hope will be the near future. I do wish he would hurry up.
Many thanks, Im fairly pleased with the way it turned out but I wish I had stripped and refinished the frameWhat a lovely looking motorised bicycle...... a credit to you.
Have a look here: https://laverdaworkshop.com/With the the extra juice from Red's charging system upgrade inspire someone to fit modern FI to an ancient triple?
Or, has it already been done?
Will the the extra juice from Red's charging system upgrade inspire someone to fit modern FI to an ancient triple?
I'd mentioned it somewhere but I found out when mounting the Redax kit on my 3C that the right hand engine cover on the early 3Cs is 2mm deeper than on the later ones meaning that the back of Reds ignition plate rubs against the starter freewheel nut.
The men in the know, well, they knew which is why Red has made a thicker base plate to keep that from happening. Exactly 2mm in it.
Many thanks to Red for having come to my rescue. Keith Nairn did as well, only his parcel never arrived but luckily was returned to him.
Original plate on the right, new thicker one on the left.
Pau
Was it obvious when fitting or only when running, I did notice the plate didnt sit completely flush and was drawn in when I tightened the mounting screwsI'd mentioned it somewhere but I found out when mounting the Redax kit on my 3C that the right hand engine cover on the early 3Cs is 2mm deeper than on the later ones meaning that the back of Reds ignition plate rubs against the starter freewheel nut.
PaulView attachment 57169View attachment 57170
When I mounted the plate, I found the pick up plate very close to the nut but didn't worry since the kit was very well made so I imagined it to be taken into account. Retrospectively, I did need to add a second washer under the backing plate screws to get them tightened down. Obviously, the pick up plate was against the nut.Was it obvious when fitting or only when running, I did notice the plate didnt sit completely flush and was drawn in when I tightened the mounting screws
Thanks Paul, the plate was clearly thinner than the original. Rather than add extra washers I shortened the screws by 2mm. It stated firsts try, runs perfectly and no unusually noise. Ill pull it off again just to double check its not interfering.When I mounted the plate, I found the pick up plate very close to the nut but didn't worry since the kit was very well made so I imagined it to be taken into account. Retrospectively, I did need to add a second washer under the backing plate screws to get them tightened down. Obviously, the pick up plate was against the nut.
I turned the engine over by hand all the time I was timing it and turned it over on the starter as well.
When I started the bike, it wasn't the easy victory I was expecting, rough running and popping .
I stopped it rapidly and saw dust in the engine cover which it turns out came from the ignition plate. The lumpy running was due to the whole thing having been pushed forwards by the nut and so probably 15° retarded.
I mounted the new set up today. It's close, only 2mm clearance. Not easy to see when it's all in place.
PaulView attachment 57183
I probably had about 1mm scrubbed off the back of the pick up plate. Makes a lot of plastic dust that's hard to miss.Thanks Paul, the plate was clearly thinner than the original. Rather than add extra washers I shortened the screws by 2mm. It stated firsts try, runs perfectly and no unusually noise. Ill pull it off again just to double check its not interfering.
if the back of the board was interfering with the seal nut the system would have shut down by nowThanks Paul, the plate was clearly thinner than the original. Rather than add extra washers I shortened the screws by 2mm. It stated firsts try, runs perfectly and no unusually noise. Ill pull it off again just to double check its not interfering.
