Another Alternative is Ryco A1657.
279mm x 96 x 61.
Should work with a bit of a squeeze or a trim, the original UFI (30.868.00) being:
270 x 93 x 48.
279mm x 96 x 61.
Great news Can you post a pic - does it have the metal strengthener ? Can you also post a link , I need one for my FormulaReading Sir Sidney's point above I just picked up two Champion U503 Air Filter's for just under a tenner for both on eBay fitment says: OPEL Ascona Kadett 849253 8949253 90027967 with cross references: GFE2160, 1457429079, AP015, C39108, LX35, QFA0878, S9079 used to fit a whole cross section of manufacturers Renault Vauxhall etc. I know sometimes eBay fitment catalogue can be a bit iffy but I am well chuffed.![]()
No not meI am in sunny Cornwall so will do so in a week should be with me by then hopefully they will be a good fit if not I am looking for someone with an Opel Kadett! I will post picture and dimensions. I may have accosted you at the petrol station in Bidford awhile back when you were out on your Corsa?
Bidford on Avon, ya puddin' - not Bideford....!No not mebut there are some Corsas down there
8mm fuel line?Here ya go..... Ryco jobbie, Fits like a cock in a Sock. (Pardon the pun Mr Sock!)
Removed the foam bit glued to the paper pleats and trimmed 5mm off rubber rib,View attachment 84898 to squeeze it in.![]()
Me too - 8mm fits fine. On that note I reckon my orig Orlandi taps might have slightly larger holes than LJ's superb replicas - doestn't seem to bother my FCRs at full song on the main jet tho.Need the flow.... when twist'n the throttle![]()
More good info, this is going straight to the pool room!Here ya go..... Ryco jobbie, Fits like a cock in a Sock. (Pardon the pun Mr Sock!)
