Rgs Rear Shocks
The shock absorber man wants to know the eye diameter for the RGS shocks. I think it's 12mm but and I can't remember for sure (frame is still at the painter's shop).
Can anyone confirm?
Thanks,
Cam
Could check tonight Cam but I think you'll get an answer before then.
Dellortoman said:
Thanks Cosi. Strange that the RGS has a tighter hole than the 180? Lavs. I'd have expected it to be the other way around  ;)
Never let a chance go by  :D :D :D
When I swapped the yss"s off the jota to the Seth African I remember that I had to get them resleeved as the whole was too big
But I did measure them, promise and all that....
Just to clarify Cam, the IKONs mounted on my RGS use a sleeve in the eye, I assume you require the diameter of the mounting bolt, not the diameter of the shocky eye.
Get back to you this evening, most probably only to confirm Cosi's measurement.
Right Cam, confirmed that the top bolt diameter is 10mm, as Cosi quoted. Assume the lower (swingarm) bolt is the same, do you need comfirmation?
terry
Regarding the YSS: I run them on the Jota without any issue at all and with perfect handling and road holding, no difference to the Wilbers from my perspective. Never had ?hlins, so I can not comment. but WAY better than Koni ever were...
BUT: I am quite heavy in comparison to Andre f.e., and that might make a big difference. The heavier springs do fit me very well where they gave Andre issues.
HTH
Rear shock threads tend to get a bit like oil threads, or tyre threads, each has his fave.All I can say is that having Wilburs on my Jota, though they are very pricey, is not something I intend to change!bootiful things they are too...the piggy back ones.
Dellortoman said:
Thanks Terry. Are you suggesting that Cosi's information is unreliable?
I'd be careful if I were you. He probably has connections with Cosa Nostra  :D
Terry's with the CFS - he could burn your house down with you in it and nobody would know it wasn't an accident.  Don't fuck with him...............  ::)
