I don't have a gas cooker and I don't touch alcohol.Any bearing puller to remove the wheel bearings is a very bad idea! Just heat the center of the wheel and the bearings will fall out.
Removing the bearing with a puller will remove a little bit of aluminum so eventually the bearings are no longer tight in the wheel. When you press the new bearings back in you are also removing more aluminum.
The next post in years from now will be, I had the wheel off to replace the tyre and the wheel bearings fell out. The fix will be red Loctite.
Put the wheel on the gas cooker so the flame touches where the brake disc mounts. Open a beer and sit down and wait a few minutes until the bearing falls out. Also use the same method to fit the new bearings. You don't need to get the wheel very hot to do this so the paint will be OK.
If you need a puller or a press or any other type of tool to replace the bearings, you are doing it wrong.
Joking apart, if your bearings fall out of a cast wheel with just a little heat, you have a problem. They need heat and judicial walloping.
