B
blabber
Guest
I always thought dukes ran backwards because the gearbox is driven by direct gear,instead of primary chain--ie it runs in opposite direction to crank.
blabber said:I always thought dukes ran backwards because the gearbox is driven by direct gear,instead of primary chain--ie it runs in opposite direction to crank.
Dellortoman said:I'll probably get banned from the forum for saying this, but I think Ducati's geared primary is a much better system than Laverda's chain primary.
laverdakeith said:What it lacks in chains it more than compensates for with shims..
Keith
VanguardontheLav said:Dellortoman said:Ducatis are the only bikes I've come across with an engine that rotates backwards. It's something that messes with my mind when doing ignition or valve timing.
The new MV F3 makes a point of running backwards doesn't it? I think they claim it improves the handling - or certainly changes it...
Dick
VanguardontheLav said:Dellortoman said:I'll probably get banned from the forum for saying this, but I think Ducati's geared primary is a much better system than Laverda's chain primary.
I doubt it, as Laverda probably also thought so, since they used geared primary for the 8-valve twins...
Which way do they rotate?
Dick
bob said:Mind you, my boys know how to operate the remote fo the TV, which is more than I can do.... and they can change the ring tone on my phone, a process which I've never been able to fathom.
