| Ne hai uno da vendere? Vendine uno uguale |
Wasn't aware GTLs came with that shape tank.An SF with a GTL Gas Tank ?
Don’t let Ron’s comments confuse you. The very first SF model, introduced end 1970 had that tank, so your bike has the correct tank, with flip up fuel cap.Thanks for the advice of knee pad suppliers, however I am not sure if it is the correct fuel tank but it’s the one fitted when I bought it, I thought the pre 71 bikes had this style of tank? mine also has the smiths clocks so I thought it was correct for the period.???
No it is an early series 0 model with Smiths gauges and knee pads, just like it should be, so I believe!An SF with a GTL Gas Tank ?
Thank you Gerald, my bike is exactly like the one in the photo, early SF series 0 with Smiths clocks.If your bike looks somewhat like this it probably is an early SF, tank and Smith clocks correct for the model.
Gerald
Not quite correct...GTL are not build in the early 1970´ . Framenumber starts with 18xxx
Rainer
