Canuck750
- Edmonton, Alberta, Canada
I have a 1973 SF1 with a pair of new round slide PHF 36mm replacement Dellorto's. Carbs are jetted to stock specification. Bike starts right up from cold with a little choke, but Its not running great and the left cylinder is cutting out. There is a spit of fuel intermittently popping out of the left side of the left carb overflow hole. On the road in second or third gear if I give it a full twist of throttle it just bogs and lacks power.
Some background on the bikes condition:
The Ignition has been replaced with a Witt unit and the coils replaced with 5 Ohm Dyna coils, new copper core high tension leads. With the Witt on test position '0' I get a strong spark out of both plugs. The engine has been overhauled (bottom end refresh by Wolfgang Haerter)new primary chain, clutch etc..., valve job done to the head, new rings, 150 psi compression on both cylinders. New fuel lines and petcocks, cleaned and sealed gas tank. Throttle has been cleaned and lubed, throttle cables are new and lubricated and are not binding, I have a couple mm of slack in the throttle cables where they enter the top of the carbs. Slides snap closed easily.
My knowledge of tuning is very limited, can anyone explain why I am getting fuel occasionally spitting out of the side of the left carb?
Thanks
Jim
Thanks
Jim
