chrissoz
- Sydney, Australia
SF1 is back together after the rebuild.
Have been out for a few shakedown runs and most things are looking good - think I have tracked down the last oil leak which was from the cam cover on the LHS (and then running down the fins and dripping out around the exhaust).
Runs strong when revs are up a bit and idles OK - but it has an intermittent but persistent backfire on the RHS cylinder. On idle and at low revs get backfires every few seconds which is annoying the neighbours and local dogs.
I swapped the output from the electronic ignition and the spark plug cables and the backfire was still on RHS so that eliminates coils and associated wiring.
I have checked the inlet manifold and sealing of the exhaust and that looks OK. Have triple checked the choke is seating properly and the throttle cables are all adjusted OK.
Any suggestions on what next to look at.
Thanks
Thanks
