harpmeister
- UK
Could anyone tell me what gauge/amperage of wire should be used between the + terminal on the battery and the regulator then on from the regulator to the ignition switch and back down to the fuse box.
Also on the wiring diagram there is a symbol with the number 18 in it between the front and rear stop switches anyone able to tell me what that is, and while I'm at it I might as well push my luck and see what is the best connecting strip to use to wire everything up to and no the budget doesn't stretch to motogadget.
Thanks in advance
Thanks in advance
