Folks,
I posted a few weeks back about my SF1 stuck in neutral and 1st. Since then I have had many adventures with gear selection and have got very oily. My SF1 will now select 1,2,3, and 4, but it goes into a false neutral when I select 5th. I have adjusted the eccentric many times but it I can never get 5th. I have turned the selector drum with a mole grips and I can easily select 4 gears but when I turn it to select 5th the drum turns but it does not select the fifth gear.
I tried riding around for a while in the hope that whatever was stopping selection would get dislodged or wash away when the engine was hot. Still no fifth gear.
Has anyone had this problem? Any thoughts on was I should do next?
Regards Colin
Regards Colin
