Lyndoneil
- Towcester uk
I know there is a countless causes of electrical problems, but I was hoping that one of the geniuses here could at least point me in the right direction, as at the moment I am totally stumped.
The symptoms are, the bike runs fine, horn works, indicators and brake lights are ok but the head lamp, rear lamp and instrument lights only work when the ignition switch is in the parking light position, in that position the flasher, dipped and main beam work fine, the parking light is also on. But when in that position the ignition is off.
The lights were ok for a while, but I don't know if I should be investigating the ignition circuit or the lighting circuit, the lack of a really good circuit diagram doesn't help.
