3CBRG
- Northern California
Not necessary to dismantle ignition switch to diagnose your issue. You need a test lamp to verify output from the proper wire out of it. Eliminate the one that comes from the battery. You lamp will light one wire with your lamp when switch is off. Call that your input (B+, probably red). That leaves the two remaining wires to consider. One ought to run the ignition, the other ignition plus the light circuit. Here's where your diagram will come in handy.l So probe the other two while switching the key to position 1 , then 2 and see which or both have output. Have you looked inside the headlight for the diode? Possibly a black widget that resembles in inline fuse holder. To avoid trying to visually trace the line through the 'spaghetti', you might want a basic multimeter to test a wire point to point (with battery disconnected).
