SkinnyPinny
- Cambridgeshire, United Kingdom
Hi all, I have blade fuses in place of the original ones, 1 x 25amp and 2 x 7.5amp, The headlight/taillight fuse blew half way into a 125 mile ride. So back at home, I started checking the connections at the fuse and headlight, cleaning the connectors etc, when I found this purple wire loose in the plastic sleeve behind the headlight.
So, questions for you lot please,
Am I ok to put a 10amp fuse in the headlight/taillight, original was 8 I think, I can’t get 8amp blades so went with the closest, ie 7.5 and what exactly is this purple wire, which goes to the temp gauge? what does this diode do and is it needed? Thanks for any help, Stuart
