Sfc1000 fuses and what is this purple wire?
there was a time when the RGS loom was used which had an electronic tacho, the SFC has a cable driven one?? the first SFC1000 had Smiths clocks both cable driven, and that was the subject of a recall to fit the white faced vague liars. cant recall, exactly but you get my drift I am sure, and this may have been the wire for the tacho, most were incirectly sent out not insulated, very sloppy from factory! someone will know more than me.
Yes Clem, do try to keep up... ;)
Vague Liars after the Smiths debacle. First few got black-faced instruments, then switched to trendy white.
the purple wire would be in the sub loom for the instrument panel instead of flapping in the breeze.”
It was in the sub loom, in the plastic sleeve, but when I was investigating I pulled it VERY gently and it clearly was not connected, if I find a permanent solution I will try to get it back in the sleeve, I have white temp gauge btw, cable speedo and tacho. I agree, a waste of effort, volt/amp would be better, maybe,
