Laverda SF
Let it be said: "Breganzies fall over, like a sheep with dropsy, when using the side stand".
Got no issues modifying the Breganzie Side Stand ;o)
However; Breganzie made the BEST Center Side in motorcycle history, to this day.
Man ! You can pull the engine out of a Breganzie just using the center stand - What more could you want.
99% of the dents in my Breganzie was caused by that terrible Side Stand. I always carried a 6"x6" piece a of 1/2 " plywood wherever I went deploying the side stand and took 5 mins to find a suitable location to park it. NEVER park your Breganzie on asphalt, when the sun is hot, using the side stand ;o(
The main issue when modifying the Breganzie side stand is that you do not over hang it and it drags in corners that can slide you OUT in deep corners. Basically, you should just adjust yourself to use the Center Stand ;o)
