Sir Sidney Ruffdiamond
- Cotwolds
Needed to get the wheels off my Corsa for tyre change and noticed that the front wheel bearing were notchy - lhs with my new chinky bearing puller one minute - speedo side not so easy the modified speedo ring is mounted on a hub that obscures the bearing - this requires removal but it is on there big time with loctite or something - have used my wifes kitchen blow lamp and my 2000 heat gun but no dice - i had the ILOC club puller but in this case there is not the clearance under the speedo gear to use it - the gear obscures 4 small screws that allow you to remove the hub - i noticed the screws were all loose so i managed to manually get them out - replaced the bearing in 30 seconds but now getting the four screws tight is going to be a problem - any suggestions ?
i had wondered if i relieved part of the speedo with my dremel to give me access to the allen head clearly would work ?
