I got the new parts from Wolfgang today and assembled the clutch. I can't start the bike for the acid test because of the clutch slave problem (another thread) so there's no oil in it, but turning it by hand it felt smooth and gripped in one direction.
Referring to Arnstein's info about the perpendicular base of the plunger holes - looking at my new ramp-ring I think I see what he means.
So that plug in the hole gets hammered off-perpendicular by the plunger which then destroys itself - and his modification is a longer plug that's braced by the ID of the outer ring, as seen in his excellent picture. Good idea and I'll do that one day but for now I just want to ride this bike once then see
everything it needs.
I assembled the slave with grease as Paul suggested in this thread
Hi everyone. I?ve got a problem I hope I can get some help with. When I press the starter button on my RGS, a grinding sound comes from the within the motor somewhere. The motor didn?t appear to be turning over, just this grinding, meshing sound. I had ridden a few blocks from home when it...
www.laverdaforum.com
where Piet also explains how to tighten the little M5 screws (loctite, tighten, hit socket with hammer gently, tighten some more, keep going til it doesn't move any more) - as Piet said I
was amazed at how much more it moved after a tap. Looks like this when done.
I used Paul's method from that thread to get it on the freewheel hub (grease it, push on hard, rotate clockwise still pushing until it slips over) - worked on the 2nd go. No nuts on wires needed.
So thanks very much for all the help with this one everybody. Now back to the clutch slave.
-Richard
