Hi Russ, I did send you a long email with pictures erlier today, did you receive it?? regards, MalcolmEmail just sent, cheers Russ
Hahaha.....I probably do not need to comment....but I remember calling you in hospital last year....and it was YOU who had to terminate theMALCOLM COX
we all love him greatly, but he will always be the short arsed shitter from Solihull.
We all have something wrong with us, yes every single one of us still alive today, Malcolm, the weirdo, DOES NOT DRINK TEA. That is a very strange one if you ask me.
Thanks Malcom, will take a look through tomorrow.Hi Russ, I did send you a long email with pictures erlier today, did you receive it?? regards, Malcolm
mine did not go beyond 86 HP with the Keihan Collector. After just changing the collector Box, it went up to 101 without loss correction (roughly 110HP engine power). If that's not a clear sign of the design beeing shit, I don't know what is...I can confirm the Keihan collector will crack. After welding it back up, it will crack again. Next system I get will be from Malcolm Cox.
Now doesn't Red make exhaust systems for the 180's?
As for the poor design of the collector preventing the bike from making any power at high revs, well my 3CL on a dyno with the Keihan made 72HP at 8200 RPM at the back wheel.
Look for a rubber door stop like this, Lothar, and that may solve your problem.basically, the Keihan collector has a reduction in diameter and is - overall - to small in size, badly designed internally (the rear ends protuded into the collector segment), which all together produced a massiv restriction in flow. And that is something you absolutely have to avoid on exhausts according to the 3 exhaust specialists I spoke to.
I am not to good at making drawings but hope this one helps to understand the difference:
And here is how it turned out in reality:
Also, the standard center stand rest (the rubber where the center stand sits against when flipped upwards) does not work anymore, which I still need to find a solution for (currently, the center stand hits the exhaust somewhere; need to install a rubber buffer somewhere but haven't found a solution yet.
yeah - was thinking of something that way, too. I need something with a far bigger diameter ...or a different mounting point for a rubber stop.Look for a rubber door stop like this, Lothar, and that may solve your problem.
Great photo!Russ I have the Armours system on a Jota 120 and I have had no issues. I prefer the Keihan silencers, I think they are better profiled and finished and a lot louder than the Armours silencers.
Here’s a photo of the bike, taken just a few hours ago, that lets you see how the system looks fitted.
And an ascetically sympathetic rack too.Great photo!
