Legs
- Adelaide Hills
A Koni (Ikon) preload adjustment C spanner works perfectly on the Marzo castellatted nut.
Vince said:The biggest issue I had was finding a thin enough 32mm openender to hold the lower nut on my Cer frontend, you need to hold the lower nut so it doesn't move when the upper nut is tightened. Ever holding it doesn't stop it becoming to tight when tightening the upper nut. I have said it before, it's more art than science. Takes a few goes to get it close to perfect. I ground down an old spanner first and then I heard on here about pushbike spanners and bought one that works great. BTW it's a 32mm hex on Cer and a Castellated nut, like rear shock adjusters on Maz forks.
Piranha Brother 2 said:And heat treated with urine!! :-*
