Lyndoneil
- Towcester uk
Oh Wise Ones.
Thought I better start a new thread, the other was getting too long
The sf is still running like a bag of shite, ticks over fine, but is pinging or knocking, pinging I reckon, hard to tell which, lazy to increase revs, but runs ok If I dare to go over 60 mph. But basically it sounds awful and on the verge of breaking down
Has a Boyer micro mk3 ignition fitted which is probably getting on.
I have checked and reset the tappets, did a compressing test both cylinders were 125-130 psi, (which isn't high, but they are very similar and I'm not intending it to be a speed machine) I've checked the carb balance with vacuum gauges which were very simular too, although in all reality it didn't seem to affect the vacuum much no matter what I turned.
I've probably totally screwed up the carb settings now!
New Boyer coil, new plugs, new copper HT leads, and new 5 ohm plug caps,
Have tested resistance on the Stators individually and together , all good 131 and 65 ish Ohms, checked all connections
I decided to strobe the ignition, the advance seems to be set at about 40 plus degrees which seems high, but for now will live with that.
Found TDC, checked several times, ran it up on the strobe and at tick over it went to full advance and as the revs increased to about 3300 ( wouldn't go higher, could be ignition or carbs) the mark remained at the full advance position may have moved slightly a degree or 2, but was fairly constant.
I tried to reset the timing to 35 degrees, but it wouldn't start, in fact I tried a few settings with no joy, possible didn't help because I was following the instructions for a 73 Triumph T120, although Boyer kindly sent me the instructions for installing the Boyer on a Laverda SF, in French. My French teacher at school told me I would regret not leaning it better, one-day.
I'm trying to get my head round it, I kind of expected the mark to be nearer the TDC at tick over and move to the advance position as the revs increased.
I no doubt are totally wrong, but it suggests to me the ignition box might have developed a fault, anyone have more idea than me?
