helicopterjim
- near Lone Butte, BC, Canada
You might become mature with time.
Maybe ripe ....... but not mature. I'm going to be stinky cheese!
Jim
Stinky cheese is fine.Maybe ripe ....... but not mature. I'm going to be stinky cheese!
Jim
It can usually move by itself.
If the cheese doesn't move, it's dead. Cheese is a living thing, like you and I...... and if it doesn't move ..... there is always prunes.
Jim
You're right on the button PaulIt's not for want of repeating it.
750s are THE Laverda.
Can't believe not one mention of the modified tubeless wheels, that's a no go for me, I'd be putting tube type tires back on
I suspect so, all I had to do was make the depression around the valve stem hole inside the wheel round so the valve stem rubber washer would seal. Can't see why a tube valve wouldn't work the same vs the original oval hole. It holds air as well as anything I've had.once you have modified the hole for the tubless valve....... can you safely go back to tubes???
Some of use fly in different circles…I can tell you are a pilot.
Jim
