AndyW
Legs said:Don't think one method is better than any other as long as the result is the same.
I agree with Cam: nothing better than light for aligning wheels. I use a laser alignment tool made just for the job.... 8) 8)
bazzee said:Vince I had to insert an extra washer like yours when I reversed the fork legs 25 (or so) years ago. It was a mystery as to why it was necessary ..
Me too Clem, made the vernier caliper thingy years and years ago, works a treat. I find if the caliper measurments are equal everything else lines up as it should.CLEMTOG said:you are right Lawrence on both counts
I align the rear wheel using a massive vernier calliper that (for me) has no other use, and I measure the distance from swing arm spindle to rear wheel spindle, however you measure it (be accurate) this will ensure the wheel is square in the frame and swing arm, .
